3ph motor to single phase thermal relay selection | Page 2 | on ElectriciansForums
Discuss 3ph motor to single phase thermal relay selection in the Commercial Electrical Advice area at ElectriciansForums.net
Use the FLC on the plate as you’re base line and as John says add 10%.
To be honest what you regard as OK, in the UK it wouldn’t.
For better advice I would recommend getting a local electrician to look at your set up.
With 30 motors running like this an artificial three phase system would be a good set up for you. Use the forum search for “artificial three phase”
Reply to 3ph motor to single phase thermal relay selection in the Commercial Electrical Advice area at ElectriciansForums.net
Merry Xmas to all :D
Hi, Thanks for that, you learn something new almost every day! Regards Griffey
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
