3phase | on ElectriciansForums
Discuss 3phase in the Electrician Talk | All Countries area at ElectriciansForums.net
P
peteludman
I have to wire up an autoclave its 3 ph 415 v 9kw and doing ohms law I get 21.6 amps the question is do I devide this by 3 or would it be 21.6 a per phase
9000/(1.732 x 400) = 13A. THIS IS WHAT EACH LINE WILL CARRY.assuming no problem with power factor.
9000/1.732 x 400 = 13A. THIS IS WHAT EACH LINE WILL CARRY.assuming no problem with power factor.
Although you got the right answer, the equation you passed on is somewhat flawed
Try 9000/1.732 then DIVIDE by 400= 12.99amps (13amps) id like to see the cable size for your 2million+ amps:eek:
Where were you baldsparkie, you missed that one lol
Now for the CORRECT way! 9000/(1.732x400) = 13A ;)
Sorted!!
Steve.
Learn from your mistakes, but don't make too many or you will know too much
Indeed I did, must be getting old Darkwood. :D:D:D Glad you have your wits about you mate.
Divide it is multiply its not.:eek:;)
Sorted!!
Steve.
Show Off !;):D
I would only add that you need to check on the auto-clave what its power factor is i.e p.f. 0.8
KVA=KW divided by p.f
so your current rating may well be a little higher (I assume you are looking at circuit protection &/or cable sizing)
Sorted!!
Steve.
Different transposition but no less or more the correct way than my solution :p it all gives the same result and thats all you need.:)
Reply to 3phase in the Electrician Talk | All Countries area at ElectriciansForums.net
Noted. Thank you. Out of phase summation being the answer to the question.
They do a cy type with pur coating and it is even tougher but is shielded
