4 month build time almost done. | on ElectriciansForums
Discuss 4 month build time almost done. in the Talk Electrician area at ElectriciansForums.net
Reply to 4 month build time almost done. in the Talk Electrician area at ElectriciansForums.net
Jumping on and off jobs can be tough going when you're less than confident as every time you go back it's like a new job. that you know little...
nicebutdim
N
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
