4 sq mm Radial - Never again! | Page 2 | on ElectriciansForums
Discuss 4 sq mm Radial - Never again! in the Australia area at ElectriciansForums.net
P
Piratepete
Had to rewire part of a house (inc kitchen) and the layout suggested that the best solution was a 32Amp 4mm radial cct for the power (sockets etc). I hadn't done one for years!
No problem doing 1st fix - 4mm is nice and flexible.
2nd fix. Using MK Logic White could get 2 x 4mm into the terminals, could just about get an extra 2.5mm in where there was a single spur (though particularly difficult on the back of a switched fused spur), but no way could I get 3 x 4mm in where I was branching off to 2 or more sockets.
Also had problems stripping 4mm cores cleanly - insulation much softer than on 2.5mm.
Anyone else had problems using 4mm. Funny thing is, my local supplier says he sells loads of 4mm!
Cheers
Pete
Did i say that?? .....Nope, What i said WAS, that previously accessories COULD take 3 X 4mm, being 12mm, but they WON'T now!! Is that plain enough?? lol!!!
Understood the first time!:rolleyes4: Whose clever idea was it to reduce the size?
I'm off to bed! Another busy day tomorrow, full of fun, no doubt! Nite
Reply to 4 sq mm Radial - Never again! in the Australia area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
