The motor is actually supplied buy 2x 100 A and an 80amp bs88 fuses (not ideal) before the star/delta contractors and these are holding up, by the looks of it the 80amp is an original.
Link out the mcb is just removing the problem not solving it plus you remove circuit protection for the socket.Link the MCB out the equation to see what happens?...
You said you had added protection in regards to the other fuses.
Know it's the the solution to your post , just a good tool to haveA handy little tool for selecting gen set sizes etc
Macfarlane Generators Power Calculator - https://www.macfarlanegenerators.com.au/power-calculator.php
