4Kw omnik inverters? | on ElectriciansForums
Discuss 4Kw omnik inverters? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
solar-spark
Hi guys,
any of you lot heard of omnik inverters? they are chinese and have a g83 cert the data sheet looks ok but ive never
heard of them just wondered if they was any good?
these seem to be the only 4kw inverters i can get my hands on at the mo.
hope you bought two one as a spare cost a fortune to send one back to china for repair
4kwp inverters lots in stock made in europe if required
scott 07934 617201 24/7 collection delivery on sat/sundays
Actually nationally the failure rate is around 2%, which is in line with everyone else, but don't let facts get in the way of a good story.
We used one Omnik inverter. We have had one failure. Suppliers were as much use a rubber crowbar. Won't be using again.
Just lost out to a quote for a 4 kW system using this inverter for ÂŁ4,700. Apparantly it swithches on an hour earlier and an hour later. I had to laugh as the design in terms of voltage range is only slightly different to the sunny boys. It wont be hours it will be minutes at most.
Oh well.....we'd have made no profit on this job if we had matched them anyway
If they're anything like the idiots that threw the job in that we saw last week then they're probably saving money on scaffold. 45 degree angle roof with a load of panels thrown on with the top panel above the ridge line.
They also saved money on a decent electrician - the DC cabling was thrown in by a roof monkey and literally no clips were used. God only knows what we'd have found if we had have digged deeper into the job.
REAL and MCS registered. So that's what you're up against.
Reply to 4Kw omnik inverters? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all. OK... Let me just try and clear a 1" square space on the screen inbetween all the highly intrusive ads.... On a site (NHS in fact) and...
Hi KungFu Turkey Leg and Mainline Thanks for the link Mainline I will see if they are any help. KungFuTurkeyLeg, as far as I can see the mppt...
