Good luck pulling that size of cable over 250m.
The electrician will supply it - well he will put the client on his kew account as long as he pays as the cables not in his budget
got a big reel organised from a mate to help distribute the cable and don't like messing about that why i thought I would ask for help.
At least 3 tonnes of cable I reckonThe reality will hit home when a low loader arrives with the cable.
Borrowing a trailored reel dispenser will tow with my 100hp tractor......was going to bury in soil thought armoured was tough......now your worrying me....will ascertain installation specs when cable is purchased so I do not f**k it up - thanks for the heads upThis still doesn't make much sense to me, if its left to the client to arrange the supply of the cable then it really does suggest that the contractor is not used to doing this kind of work or using this size of cable.
What do you mean by a big reel? You're going to need to be careful how the cable is pulled in or laid as it is surprisingly easy to damage big armoured cable when doing this.
Cables can be damaged by pulling too hard on them and by incorrect attachment of the pulling rope, cable manufacturers will state the maximum pulling force and method of attaching the rope.
Are you aware that the cable needs to be laid in soft sand to avoid damage to the sheath, marker tape or tiles will need to be installed and sheath tests will need to be done to ensure that no damage has occurred to the sheath during laying the cable.
With the greatest of respect Buzz - I am getting someone in to do live up the wire - I am a groundworks professional and installing a cable into a trench is not exactly testing i will be carefull and walk the trench to ensure there is nothing sharp in there - following davesparks advice i will now encase the cable in sand for belts and braces approach.I would go for a speaclist company for laying it , it amaze me when peaple say i will do it me self save the cost get some body in .
Have you got plenty of cable rollers to prevent drag.
End up being 95mm at the tractor end.Definitly need rollers on this job.
Using even 200m of 4 core 120mm (can't find the weight for 5 core) cable will weigh just over 1480kg.
Not just damage caused by catching debris in the trench. At that weight, pulling with a tractor without rollers will likely stretch and damage the cable anyway.
Thanks Rob- yes have got a roller organizedDefinitly need rollers on this job.
Reply to the thread, titled "5 core SWA 120mm pvc cable" which is posted in Commercial Electrical Advice on Electricians Forums.
