5 flats....1 EICR?? | Page 2 | on ElectriciansForums
Discuss 5 flats....1 EICR?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Reply to 5 flats....1 EICR?? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It won't be notifiable though as its not a new circuit, if you change the the tails from 16mm to 25mm is that notifiable? No, if you add an...
Definitely, although most likely within the accessories. I've often found that once accessories are disconnected the cabling IR is fine. Sometimes...
