Guest viewing limit reached
Weighed Buzz Weighed, he doesn't improve with age.:eek::)
He only spells his name right, cos it’s written on his pyjamas.
Seriously, that is a shambles of a job. I’d be surprised if there is a CU to speak of. Will be all supplied from what’s left of an old Wylex fuseboard or something.... with nails instead of fuses!
The guy that did the work was from Spain . The worst bit was the installation was energised and bonding conductor had been cut and left hanging. 8 junction boxes in kitchen area, with no way to access them. Shower and sockets on same circuit. No earth sleeves throughout and no continuity of cpc
Well the bit saying "Enchufez Plant." is either mis spelt Spanish or Portuguese for "socket supply " more or less translated, and the whole thing looks a bit South American, but safer.
Still I don't see anything live you can actually touch, just rather a lot of single insulation, and a feeling they are not used to the bare CPC in T and E. How do the breaker or fuse ratings and cable sizes stack up?
Hi M - strangely I feel that wiring systems are a bit like icebergs, in that only a small % is ever on display. And the bit the installer knew would be seen is likely to be their best efforts :eek: .
Either Spanish or Portugese, badly spelt. I won't condemn hin because of that, because I have seen lots of really good Spanish electrics...
(he lied)
Unfortunately many people have no knowledge of electrics. I neither am nor was an electrician, but when a neighbour asked me (as a schoolboy) to look at the broken cable in his house which they "repaired" but didn't work, I could see the problem. They had basically wrapped all three wires from each end together. At least they had put some tape round it!!
EDMOND MATOSHI,
Mr K Barrett,
