View the thread, titled "6mm Main Bonding on TN-S domestic install" which is posted in Domestic Electrician Forum on Electricians Forums.
F
freedomrun
TN-S, 60A Main Fuse, 16mm Tails, 16mm Earth.
Question - CU change required & at the moment has 6mm Main Earth Bonding to gas & Water, less than 0.05 Ohms continuity measured & good condition. I'm pretty sure that this 6mm size Main bonding is compliant - just thought i would check if i should be aware of any other issue with leaving this in place. Thanks.
there's a lot of answers in this thread if you bothered to read it. seeing as how you've made the effort to resurrect it after over 2 years.
And i can't see why you would leave a 6mm in place at a time of undertaking a re-wire, ....what to save a couple of quid or so!! It's Nonsense to me!!
Reply to the thread, titled "6mm Main Bonding on TN-S domestic install" which is posted in Domestic Electrician Forum on Electricians Forums.
