A good example why not to use a Twist connector! | on ElectriciansForums
Discuss A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
timbobelfast
Belfast
Found this badboy this afternoon after someone reported a break down in the kitchen area.
[ElectriciansForums.net] A good example why not to use a Twist connector![ElectriciansForums.net] A good example why not to use a Twist connector![ElectriciansForums.net] A good example why not to use a Twist connector!
Stripped out hundreds of ceramic ones when I was serving my time and they were fine for multistranded vir cable at the type but were no good for single core cable fast forward 35 years and this import from America is doing the rounds and I cannot think why we should use it inplace of connector block
I've noticed a couple of companies are doing some fairly aggressive marketing for these thing recently. I assumed they'd made some improvements to the design....maybe not. They're pretty common in appliances manufactured in the US, I've got no idea why the Yanks love them so much.
well for a start...recently at the show in manchester i had folk pushing these things under my nose...i was suspicious about em then...still am..that didn`t stop me grabbing a large fistful though and..
secondly....well you have already answered your question `why the yanks love em so much`.... well of course its because they make em there.........
tin hat on.i like them,only used the twister pro ones(are they designed to match your c&k gear,probaby a ploy) i like wago and chock block and crimps,no matter what you use its only as good as the spark connecting it up,
this is it...they looked alrite when i had a go with em at the elex show in manchester....my only concern here with em though is differing tempretures causin em to work loose over time....
Reply to A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
