Discuss A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
this is it...they looked alrite when i had a go with em at the elex show in manchester....my only concern here with em though is differing tempretures causin em to work loose over time....
yep but wago`s n hellemans will accomodate tempreture difference....a lot of these connectors coming onto the market will clearly struggle with it...you only have to look at some of em...fair point,on any connector i suppose,but still better than choc block,
well i cant see it Lenny...after all the jury is still out on wago`s isn`t it and they are clearly better than this....I wonder if they've acheived BSEN or ISO conformity yet. Last time I inquired, they hadn't.
dont get me wrong...i like crimps and will use em wherever appropriate.....i just look at some of this stuff.....and think it isn`t even a go-er.....all those twisters are doing is twisting the cable together,we were taught to do the same with pliers at college,now people dont twist cables,a push in connector can cause problems over time its only a spring,so crimping would be the best method but theres always a need for faster connections and the twisters and wagos offer that.
these `twisters` as they go by...they still need to be in an enclosure....I seem to remember these twisty things also do a IP rated twisty things. with a gel. But TBH they looked even more questionable than the normal ones , couldnt get my head around em. seemed so vulnerable.
shouldn`t affect testing though should it....you test an install with the socket fronts IN PLACE.....your R1+Rn & R1+R2 confirms wether correct polarity has been acheaved.....now if you had said inspections...well then thats a different matter...now, i dont like twisted CPCs n stuff like that...but at a socket it dont effect the testing process.....different matter at the board/CU though....In my opinion, anything that involves twisting cables is a pain in the a*** when coming to testing. It really peeves me when i test at a socket and the lives and cpc are twisted, but thats another thread.:veryangry2:
Reply to A good example why not to use a Twist connector! in the UK Electrical Forum area at ElectriciansForums.net
