Hi all,
I'm working on a new estimating spreadsheet. I've got the nuts and bolts of it together, but I could do with a little help.
Part of the spreadsheet will have ready made tasks or points. What I mean by this is common tasks where all the materials and labour allowances are bunched together. For example a double socket (flush) point. 8-10 mtrs of 2.5mm 6242Y, 2 mtrs 25mm oval (or channel), 1 x 2gang flush metal box, 1 x double socket face plate. You get my point?
Obviously most of these are easy, a single socket point, TV point, switch fuse spur point, cooker point and outlet, 1gang switch point, recessed light point etc.
Other more involved tasks/point would be say an inline shower fan with light and timer. These will have more component parts etc. So since It's hard work sitting here trying to think up all the points already mentioned, could anyone suggest other common tasks I may not think of and list the items.
There will be a reward here. Anyone that helps me out will receive a copy of this. I'll have done all the hard work putting it together all you have to do is make a few suggestions.
Just so you don't think this is pie in the sky, here are some screen shots of what I already have. This is no one page estimate spreadsheet. This is going to be quite big by the time I've finished and even then I'll most likely try to improve it.
Anyway, some screen shots:
