A question from a mate | on ElectriciansForums
Discuss A question from a mate in the Electrical Course Trainees Only area at ElectriciansForums.net
T
trev
Hello all, long time no speak
I was talking to a mate of mine the other day about this place and he emailed me a question he set to a class of apprentices. I've not had a go at it (yet). Have a try-
3 single phase heating elements are fed from a 3 phase 4 wire 400 volt supply. Assume each element is 2KW at 230 V. The switch is in the neutral (once upon a time it was allowed)
Calculate the heat output
A with the switch open.
B with the switch closed
I have the answers but as I said above, I've not worked through it myself yet
Very good question indeed and I can see what reply your after which I'll leave to the Trainee's of course :)
TBH I would be interested to see this question in the main forum too after its run its course in here ... its a thinker for most levels
:devilish:
Is it within your mod powers to copy and paste it into open forum or shall I just reproduce it when the time comes mate?
I know but was going to let it run as your little baby in here first ..didn't want to steel any thunder plus didn't want the Trainee's seeing the answer in the main forum which is the main reason to do it later ;)
could somebody explain to me how to work it out please?
With trev's agreement I'll ask Marvo to undelete his post which is a wiring layout to better explain what is happening, now that the answer is out there I don't think there is any issue to explaining indepth the reasoning behind the answer.
Reply to A question from a mate in the Electrical Course Trainees Only area at ElectriciansForums.net
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
The total current capacity of the system in amperes is the same as the per-phase rating when referring to a balanced three-phase system. Thus, a...
