A reminder to everyone - FatallyFlawed - Child Plug Socket Covers Campaign
If you look on the Fatally Flawed web site you will find more information. As I said they are classified as a “TOY”. Stupid but true!
So at the end of the day all you can do as an electrician is recommend their removal.
OFSTED just dither and will not make a positive decision regarding their removal from nurseries and schools, it’s down the owners to make the decision.
Already banned them from our house when our eldest arrived three years ago, just thought they were pointless. Didn't realise just how dangerous they were. I'll remember to check if they are using them at our kids pre school.
The British Standard is more than sufficient, these "safety covers" are just an attempt to create a market by instilling fear and doubt in the consumer's mind.
Such a practice is prohibited in some situations, as it should be in this instance
Mikep
So you go into a nursery to do a periodic and you find a toy jammed into every socket outlet; and you're going to leave that site with no more than a recommendation.
I’m sorry but please don’t shoot the messenger, I didn’t make up the regulations.
If I had my way there would be legislation against them. But it’s up the higher powers than us mere mortals to get off their fat arses to make a decision. The IET are aware of the problem, but……….
I’ve been against them since my son was born 27 years ago, my brother, also an electrical engineer even bought some for us. He was offended when I threw them in the bin until I showed him the problems with them. He removed them as soon as he got home. There again he was a cheapskate and had fitted Crabtree sockets in his house, were I’d fitted MK. I defy anyone to push something in the a MK socket with the cam shutters. Even for someone with the knowledge of how they work it isn’t easy.
I’m just trying to be the messenger, as I hope you and others will be.
With all the evidence compiled in such a professional idiot proof format how can the government still allow these ridiculously dangerous pieces of plastic to be sold in the uk?
We can only campaign against them for now. But as time passes we may make progress. The big problem is TIME!
I’m sorry but at the moment it’s the best I / we can offer.
was looking at a relatives house where there was a child and i explained to them about this fatally flawed campaign, yet they insisted they were more protective. they then told me to try and take them off and it really did take a load of force to pull it out, much more then a child would be able to do anyways.
It is common for parents to report that small children can remove socket covers much more easily than they can themselves. there are a number of examples of this on our user comments page.
Because plugs have tightly specified dimensions, the force required to insert and remove them is really a function of the design of the socket and its contacts. However, because no socket covers are made to the correct dimensions of a plug then it is common for them to be either significantly easier to remove or significantly harder, depending on the particular combination of socket cover and socket. If the socket cover takes a lot of force to remove then that is a good indicator of a cover which has oversize and/or incorrectly spaced pins, both of which can cause permanent damage to a socket!
Parents tend to think that a hard to remove cover is a good thing, they find it difficult to understand that it probably means they have caused damage.
The Electrical Safety Council has published a leaflet warning about incorrectly sized pins on sub-standard chargers, this says: "If the charger does not easily plug into a socket, the pins may be the wrong size or length, or the distance between the pins may be wrong. If pins do not fit properly into the socket, overheating, arcing and mechanical damage can occur to both the socket and the charger, which can be dangerous." Strangely the ESC are unconcerned about incorrectly sized pins on socket covers, even though the potential for mechanical damage (and therefore subsequent poor contacts) is exactly the same!
I assume by cam shutters you are referring to the sockets that had the twisting shutters on the L & N if so they were that good that a HTM was issued highlighting safety issues with them and they were banned from health authority sites in favour of Crabtree, the issue being that you could insert a 2 pin plug and for that matter a 3 pin plug with a missing or broken earth pin or a continental shuko type plug. Hence why MK returned to the original shutter type
If they take more force to remove than that exerted to remove a normal plug top then what damage are they doing to the socket these things are quite prone to breaking and leaving pins in the socket and IMO the tighter they are the more likely this is to happen leaving the socket in a dangerous condition
That is a very interesting snippet about MK. The draft of the next revision of BS 1363 includes a clause to ensure that it will be impossible to insert a two pin plug. To be fair to MK, the Logic Plus range uses a three pin shutter opening method where the earth pin insertion unlocks the mechanism to allow simultaneous insertion of the other two pins, quite different from the original method.
Thanks UNG. Useful information. As you all know I’ve never really done domestic so this is the first I’ve heard about the modifications the MK shutter system. By the sounds of it we’re going to have to be safe crackers to defeat a socket.
They are fatally flawed, furthermore they encourage kids to play with them increasing the risk.
Knobhead,
littlespark,
