abit of help please | Page 2 | on ElectriciansForums
Discuss abit of help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Just gotta work hard on remembering things as well as being composed and reading questions properly so that you can answer only what is being asked, also, learning the way that they like questions answered and set out.
Well done mate, you will soon see just how valuable it will be. I passed the feb 2012 paper. Obviously our learning is never done, try and use your knowledge ASAP though (if you're not already testing) because things do get forgotten quickly.
As a side note, how looked down upon will 2394/5 be? I know it's equivalent anyway so should be treated the same, whether it will be or not is another matter.
Reply to abit of help please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You’d have to change the size but you could just fit an LED panel behind the Perspex or whatever it is you’re using for the opaque top. Sizes of...
Not to mention welding switch contacts together and wondering why when they thought they had got the wiring sussed the light will still not switch...
