Abs and glow plug light errors,blowing 80 amp fuse. | Page 3 | on ElectriciansForums
Discuss Abs and glow plug light errors,blowing 80 amp fuse. in the Auto Electrician Forum area at ElectriciansForums.net
Cheers peg will do,yeh smokes quite badly,even when it worked for a couple of days it smoked but didnt blow,theres 3 fuses in this box attached to positive on battery 80 amp abs 80 amp alternator and 30 amp its got comp on box lid i presume compressor?? The abs fuse as also got something else written on box but cant make out what it says,i have seen a schematic and it says abd but doesnt look like that on box two wires go into this one fuse though a red and a white.
Hi all,i just want,to say a massive thank you to the guys who,ve been giving loads of excellent advice over the last few days thank you,oh and just a quick update,i recieved my new fuses this morning,i began to do the tests u was advised to do,it never rains hey,dont buy cheap glow plugs is the message here,tws6s ate cancelled,the 1st plug i tried the nut holding it wont undo the the top of glow plug the cables attached too its all turning the top is nurled and push fitted in cheapo crappio,so ive stopped,put new fuse in and car does all it should again but no smoke from fuse this time,i will say i paid double for these fuses,company called durite miles better made im waiting for engine to cool then try again its started a dozen times upto now but watch this space.cheers again guys.
Reply to Abs and glow plug light errors,blowing 80 amp fuse. in the Auto Electrician Forum area at ElectriciansForums.net
