Acegoo Wireless Lights Switch | Page 2 | on ElectriciansForums
Discuss Acegoo Wireless Lights Switch in the Lighting Forum area at ElectriciansForums.net
The red and black going through the box may not be the same circuit. Ie feed for downstairs passing through an upstairs switch.
Can one of the old boys tell me when these colour combination went out of use?
definitely pre 1977
It doesn't look like it is but Octoflex which was a prefabricated system used colours for conductor purpose. So a blue would be a strapper for L1 and L2 and white line output to the light fitting.
definitely pre 1977
I remember Aracon prewired conduit that was formed in the shape of T+E never come across Octoflex maybe the O.P. can tell us if it is metal conduit?
Containment appears to differ, the upper entry seems square pvc and the lower is tube, either corroded steel or it could be brown plastic.
Hello,
i am in a similar prb. i want to fix this receiver for one way only can anyone look into the below images and let me know which wire to connect which one please??
[ElectriciansForums.net] Acegoo Wireless Lights Switch [ElectriciansForums.net] Acegoo Wireless Lights Switch
Reply to Acegoo Wireless Lights Switch in the Lighting Forum area at ElectriciansForums.net
Given the obvious limited capacity of whoever fitted the switch and who knows what else, I'd be keen to check the "earth" is definitely connected...
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
