Adapt this CU........... | Page 2 | on ElectriciansForums
Discuss Adapt this CU........... in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
OK - this is a dual board, about 3 years old ......... 1 RCD per bank.
They are experiencing random tripping, and my trusty earth leakage clamp shows that both banks are running at around 21 mA leakage - so the smallest change plunges half the house into darkness etc.
Anyone know if I could easily source the parts to add 2 more RCD's (yes I realise some circuit consolidation would be required ....
[ElectriciansForums.net] Adapt this CU...........
And no I didn't install this!
I had the same issue on a stackable Hager 36 way board. Lots of electronics and control system were leaking due to design.
We added another neutral bar and put rings, cooker and kitchen on rcbo's. Problem went away, I think adding an RCD would be more hassle than it's worth.
How does adding another neutral bar solve the problem ?
The only thing that makes sense is that it lowers the neutral systems impedance.
In which case that indicates a failing or poor neutral system to start with.
Adding a neutral bar would enable RCBO's to be added .... then the higher leaking circuits could be on them, reducing the cumulative leakage on the current RCD's.
Having 13 MCB's on RCD wasn't a great idea to start with!
Too much earth leakage going through the rcds . adding another neutral bar allows the earth leakage to be split across more devices .
never mind, pete, aldi is open till 21.00 hrs. send mrs. pete out. if you're lucky, might get a pie as well.
Not possible for Mrs Pete999 to get about much these days Tel, and to be honest I really can't be bothered, as well as the drink driving issue, I'LL wait till I get back from ELEX tomorrow. Pick up 1 or 6 on the way home.
Reply to Adapt this CU........... in the UK Electrical Forum area at ElectriciansForums.net
