Adaptable box with front entry. | Page 4 | on ElectriciansForums
Discuss Adaptable box with front entry. in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
Liverpool
I’m looking to fix a previous install. After having some rendering I have a feed that’s in 10mm T&E and I’m looking to replace the conduit. The gate is being replaced. I’m just looking for an adaptable box that I can have conduit come out the front.
I’ve decided to have the conduit come out from a Wiska box go down the side of the house and then across the gate with a length of conduit into another Wiska box and then another length into an Adaptable Box and go into the rear into the Garage and into the sub main board.
Any help or advice would be great.
  • [ElectriciansForums.net] Adaptable box with front entry.
It was put in place as a temporary measure as we needed a cable to feed the garage. I will look at steel conduit. I don’t own a bending machine and I would image a 90 would be hard to pull 10mm T&E in.
I was thinking End box from the house, down into another end box and then see if I can find something with a thread on that I can have a straight piece for across the gate. Then another angle box straight across into the last end box into the garage.
I’ve never painted steel conduit. Would any metal paint do? Or is there a specific type that is needed?
As I say I’m open to suggestions with steel conduit.
You can get a threaded lid for steel conduit, you could put an end box on and thread it straight into the lid, although 10mm t and e is going to be awkward no matter which way you do it. I believe hammerite will take to galvanised metal but I stand to be corrected.
Have you got a link to it? Or the best place to buy it from?
That's a 20mm but they are available in 25mm also. Not sure I'd buy with this company though, pretty poor experiences with them.
Okay thanks I will have a look online. I will see who out of the wholesalers is the best priced. Also I will need a tap and die set.
If you are insistent on not burying get a few lengths of 25mm galv tube and the appropriate fittings in con lock you won’t need a bender of dia set then
I know what you mean about burying the cable. It would be a bit of hassle trying to lift up the blocks as they’ve been cemented in. I’ve not heard of con lock. Where would be the best place to get it from?
Cef Hyton stocks it basically it it conduit box’s and bends with a Alan key to lock in place and not threaded
Reply to Adaptable box with front entry. in the UK Electrical Forum area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
And if it's a garage then use metal clad accessories.
