Adding a Fuse Spur on to a Consumer Unit Circuit | Page 4 | on ElectriciansForums
Discuss Adding a Fuse Spur on to a Consumer Unit Circuit in the UK Electrical Forum area at ElectriciansForums.net
RDB85
Trainee
Liverpool
I’ve had a disagreement with one of the Engineers in work. So we are doing an install. Installing an Intruder Alarm. Rather than go with my suggestion of coming off a Socket and adding in the Fuse Spur as he’s been doing it 15 years it’s now going next to the Consumer Unit. Which at a guess is 20 years old. He said it’s fine to just add in a circuit to an existing circuit.
Myself personally I’m dead against it. He’s not a qualified electrician. Thoughts?
Howcomes?
Because I don't think it is good practice to connect non-lighting loads to lighting circuits unless they specifically need to be on that circuit (Such as a bathroom extract which needs to be switched with the light)
I see no reason why a burglar alarm would need to be fed via a lighting circuit.
What's the difference electrically between adding a single pendant straight from the breaker on a lighting circuit and adding a single pendant to the end of the line?
No difference at all, but my comment wasn't about adding a light to a lighting circuit, it was about using a lighting circuit to feed a non-lighting load.
Reply to Adding a Fuse Spur on to a Consumer Unit Circuit in the UK Electrical Forum area at ElectriciansForums.net
Issue is certain sizes of cable may theoretically be okay but upon the proper testing when it’s commissioned things like a thing may not test out...
