Adding a spur to a spur | Page 2 | on ElectriciansForums
Discuss Adding a spur to a spur in the UK Electrical Forum area at ElectriciansForums.net
Leicester
I have a socket which is connected off the main circuit ring.
Just wanted to know if it's possible to add another socket spurring off this second socket?
(Please see attached image.)
If it's against regulations, then
1) what's the worst that could happen? (Will my circuits blow up?)
2) what's the best alternative and what size wiring will I need?
[ElectriciansForums.net] Adding a spur to a spur
It is an interesting phenomena that anyone other than a bona fida time served electrician with at least 100 years of experience is incapable of altering a ring circuit and it remaining a ring circuit on completion.
Given that a circuit really does not get any simpler, just a big loop, it really does defy logical explanation.
Kev is the worst offender, I have never, ever come across a kitchen ring altered by Kev that is still a ring. It should be a legal requirement that any sockets altered or installed by Kev must have the OCPD reduced to a maximum 20a. Mind you, Kev would see that as a green light to wire his multiple spurs in 1.0mm.....so prap's not.
Reply to Adding a spur to a spur in the UK Electrical Forum area at ElectriciansForums.net
K
Ah, I see. The op question is ambiguous, and I took it that he wanted to add a socket for a washing machine from and exiting switch fused spur. A...
Many thanks. Very clear!
