Adding a spur to an existing circuit on a BS3036 CU | Page 4 | on ElectriciansForums
Discuss Adding a spur to an existing circuit on a BS3036 CU in the UK Electrical Forum area at ElectriciansForums.net
E
electro-lass
Hi there,
I'm a newly trained electrician with limited experience and could really use some expert advice. I've searched through the forum about this but have only managed to confuse myself further. I have been asked to add a double socket to a living room ring circuit. My plan is to spur off an existing socket in the living room running the cable under the floor boards. The CU is a Wylex BS3036 board. To comply with regulations, does the double socket that I install have to be RCD protected?
Wouldn't that be a little extreme for one socket ,you are then responsible for any faults that arise on other circuits not practical for a single socket addition.
Maybe , you would test all circuits prior, just don't like breaking out of cu just to rcd one circuit!!?, would rather change the cu.
It's about being practical if you are supplying a new socket lets say ÂŁ70 you then tell the customer you need a new rcd board with eic to supply one socket at ÂŁ350 what would you say?
Generally with a 4 year apprenticeship
I got me an apprentaship, best way to describe most of the guys is.
Dodgy dave, neville and an adhd midget.
Its a great apprentaship with our own monkeys in house to show you the wrong way so you't have don't have to make the mistake XD
A lot of bms work so see a lot of crap hit the fan so need to constantly re purposes cables, add more, deviate from panel drawings because it needs panel mods but no one nows what because they havent been delivered to site yet.
Hu??
You on the drink?
Boydy
Forget the apprenticeship and take an english course.
Reply to Adding a spur to an existing circuit on a BS3036 CU in the UK Electrical Forum area at ElectriciansForums.net
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
An example of the long term race to the bottom of quality of work in our industry, IMHO.
