Adding liquidtight to rigid metal conduit | Page 2 | on ElectriciansForums
Discuss Adding liquidtight to rigid metal conduit in the USA Electrical Forum area at ElectriciansForums.net
BlueBaron
Californis
Hello I have an existing run of rigid metal conduit outside of my house that feeds several outdoor receptacles. There is no separate ground wire inside the rigid metal conduit. Is there a way that I can use liquid tight to run to a new extension receptacle? What I am particularly concerned about is how to make sure that I have the grounding right. There is no existing ground wire within the rigid metal conduit. Thank you
Megawatt, Thank you. Could you please tell me what the simplest ways to do this? Thanks so much for your help. I’ve gotten a ton of great help from this forum.
The best way I know is if you have a meter and put it on the OHMS setting and get a long piece of wire long enough to get to your panel and attach it to your last receptacle grounding electrode. On your meter Red lead on your neutral bar and the black lead on the wire coming from the last receptacle. It’s a little unorthodox but it works. You are looking for continuity between the panel and your receptacles
Metallic liquid tight conduit in under 6' lengths & circuits 20A is usually permitted for grounding*, I don't really care for it, but there are other ways too.
*It should be printed on the jacket.
Reply to Adding liquidtight to rigid metal conduit in the USA Electrical Forum area at ElectriciansForums.net
As long as the existing wiring is approved for outdoor use and everything is working as planned then there is no need to replace the wiring.
Thanks guys, I ran UF-B. Never handled 6/2 before, wasn't as difficult as I expected.
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
