Adding RCD spur doesn't set but consumer RCD is fine | Page 2 | on ElectriciansForums
Discuss Adding RCD spur doesn't set but consumer RCD is fine in the UK Electrical Forum area at ElectriciansForums.net
Stevie186
Home
Hi all,
I have ran added a fused RCD spur off a socket to feed some electric gates. I figured as it was going outside I would put an RCD on the spur on it as I had one kicking around I believe it's probably unnecessary but when I connect it to the supply it will never set and constantly trips? The RCD in the consumer unit is fine though and I have tested and it trips out as it should? I can't understand no matter where I try and put this RCD spur it never sets, I tried wiring into a few different sockets and still the same. Any ideas? I have tried 2 different units and still the same They are the safetysure metal clad RCDs spurs if that makes any difference.
Steve
Debatable. It appears to have been a deliberate omission due to the wording of BS 7288:2016.
This is what I'm hearing, it's down to the manufacturers to state their devices comply for use as additional protection. It wasn't an omission but someone finally noticed they didn't comply.
Not many electricians are aware of this but then take into account other trades, such as plumbers, trying to do the right thing and are unaware of this change. this needs to be widely advertised.
Reply to Adding RCD spur doesn't set but consumer RCD is fine in the UK Electrical Forum area at ElectriciansForums.net
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
2 3
