adding shower CU | on ElectriciansForums
Discuss adding shower CU in the UK Electrical Forum area at ElectriciansForums.net
hi
just wanted to check something,
when adding a seperate shower CU (split tails) from a 80amp or even 100amp main supply the tails feeding the shower CU do they have to now be 25mm? or will 16mm be adequate due to the fixed load of the shower
The seperate shower cu (63amp 30ma RCD) is this again due to the CU supplying one fixed load so no need to be rated at the 100 or 80amp supply fuse
many thanks
its ok now have it sorted, 11kw shower will only draw 47.8 amps max so the 63amp rcd is fine.
same for tails supplying shower CU max of 47.8amps so 16mm would be fine. got confused with minimum of 25mm for MAIN TAILS for above 60amp main fuse
11kW shower makes a complete mockery of fitting energy saving lamps. how many low energy lamps would it take to recoup the extra, non-essential 3kW in that shower.?
That 3kw will probably never be used, mostly down to humans having that issue with excessive heat
Anyway, Looking at the manufactures cables inside the average shower I'd say none of them will ever draw anything close to that and manufactures are just playing it safe
if you split the mains tails and the incoming fuse is 80amp your new cu for the shower main switch would have to be 80amp rated 16 mm tails are sufficient
so why do all of the shower rcd units come with a 63A rcd/mainswitch doesnt make any sense especially as most shower manufactures state there showers must be connected to at least an 80amp mainswitch also
Reply to adding shower CU in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
