adding shower CU | Page 3 | on ElectriciansForums
Discuss adding shower CU in the UK Electrical Forum area at ElectriciansForums.net
hi
just wanted to check something,
when adding a seperate shower CU (split tails) from a 80amp or even 100amp main supply the tails feeding the shower CU do they have to now be 25mm? or will 16mm be adequate due to the fixed load of the shower
The seperate shower cu (63amp 30ma RCD) is this again due to the CU supplying one fixed load so no need to be rated at the 100 or 80amp supply fuse
many thanks
yes the mcb will protect the shower cable but i was mistakenly thinking that the rcd switch/current rating would have to be 80 amps for a 80amp supply fuse but if it is a fixed load of only 45amps then thats the maximum the rcd would need to be rated at.
Reply to adding shower CU in the UK Electrical Forum area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
