Adding wall lights | Page 5 | on ElectriciansForums
Discuss Adding wall lights in the UK Electrical Forum area at ElectriciansForums.net
Loky11
North yorkshire
Hi chaps,
I'm wanting to add a couple of wall lights in my dining room, which currently only has a single pendant which is wired through a junction box some where, now do wall lights require a neutral? If so what's the easiest way to get a neutral to switch? I know I will have to swap the current 1 gang switch for a 2 gang switch obv. Thanks.
Reply to Adding wall lights in the UK Electrical Forum area at ElectriciansForums.net
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
Double pole switches? Mounted on a grid module? Ignore the fact they have a N stamped on them. Or is your 2 gang switch decorative, and you...
