Discuss Additional Fuseboard with 100A RCD Main Switch - need to fit standard main switch ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
hi all
i have a qiuestion, i need fit extra fuseboard, because i cant upgrade currently, because i have no free socket for new braker, so i need fit new, with 4 braker, i have this unithttp://www.*************/p/wylex-5-way-100a-rcd-board/44086 from ScrewFix - cat no is: 44086 brand new so in screwfix said i can use this, electrician have to split supply and can connenct tail streight away form hanley box to this unit without Main Swich because this i RCD and Swich in on pice , so that is tru, can i do like that or i need unit with 100A Switch plus RCD
Re: Additional Fuseboard with 100A RCD Main Switch - need to fit standard main switch
who will be doing the work
whats the explanation going to be to the paramedics of the fire brigade going to be
i went to screw fix and the told be put this in ere an that in there then there was this big bang in it and then a bright light the ouse was on fire in it while wife was scraping me off the wall
TOTALLY AGREE WITH YOU MATE, OP : Is this Commercial or Domestic ? If Domestic then before Changing or Adding a Consumer unit you need to be Part P certified or Notify your LABC. As far as i'm aware Screwfix staff are not technically trained & therefore are not competent to give you this advice, you need to consult a Good Qualified Electrician before going any further.
@Specialist this is domestic, in my costumer house, so this job do for my some certyficated electrician... i just wanna ask firs, if i can't use this fuseboard its fine, i just buy other one, standard combination, RCD + Main Switch, i ask because i have one, so i think i can save the money but if not, i need to buy new, or maybe buy just Main swich and fit inside ??
Would'nt it be easier in the long run to just upgrade your CU to a 17th edition board that had the required amount of breakers ? rather than have 2 CU's.
Ah now i see your problem, at the moment i can't get on the Screwfix website to check out the CU you've bought maybe 1 of the other guys will have more luck & be able to give you the help you need. If it has RCD protection though I can't see why there would be a problem with useing it.
Reply to Additional Fuseboard with 100A RCD Main Switch - need to fit standard main switch ?? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
