Additional Kitchen ring? | Page 2 | on ElectriciansForums
Discuss Additional Kitchen ring? in the UK Electrical Forum area at ElectriciansForums.net
Nottingham
Hi
A client is having a new kitchen installed and they have requested 8 new sockets in various places, there are currently 8 sockets installed.
The consumer unit has couple of spare ways and located in the kitchen, also Im installing downlight from below so the ceiling will be no problem to make holes etc.. I could also install majority of the new ring without removing any old units or causing much disruption for the client
I was just after some opinions whether to install a new ring main for the new sockets or just extend the existing ring main circuit. Its a 5 bed detached house and it has two existing rings..sockets up and down & kitchen and utility
All advice greatly appreciated
Then consider common sense .............. a customer can only use so many appliances / accessories at once
AND go back in time and lots of houses only had 1 socket circuit and that often included the immersion.
Extend what you have.
Horses for courses. The kitchen I'm doing at the moment has a ring for general use, along with separate 20a radials for oven, steam oven, boiling water outlet, built in coffee machine, and a 32a radial for dishwasher/vacuum drawer/waste disposal. I'd always try and keep appliances off a kitchen ring simply because it minimises disruption in the event of faults.
But then that's a different thing, your case, OP case needs to provide more info.
Reply to Additional Kitchen ring? in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
