additional protection | on ElectriciansForums
Guest viewing is limited
Discuss additional protection in the UK Electrical Forum area at ElectriciansForums.net
L
lofts
right again this is not a **** take im just trying to make sure I do things right.
again the house im working on at the moment does not have a duel rcd boar there is a rcd in there but im not sure if its rotecting just some of the circuits or all of them. its this one MEM MEMERA 2000 AD WAY CONSUMER UNIT INC 6 MCB'S AND RCD'S | eBay
im sure that this board will mean that I need to install suplimentary bonding in the bathroom. and so will be linking the hot and hold pipeing on the wash basin together I think this needs to be continuos but again im not sure. when I say continuous i mean no cuts/breaks in it which is easy enough to do. Im presuming this cable will go all the way back to the main earthing terminal in the board. if there was a MET block like you get on page 15 on the on site guide (red one though) would i then take this cable back to that.
another thing im unsure of is what size should this conductor be. is it 10mm
thanks agin for any help assistance or nudging ti the right direction so I can understand this.
pps if theres a towel rail to be installed as well I would also need to bond this, could I do this with a seperate bonding conductor again taking it back to the MET if there is one or the earth bar in the cu or would it be best to do them all with just the one binding conductor linking them up so its a continuos run.
I do pthat makes sense
cheers
Why can you not establish what's rcd protected and what isn't? You need to know, find out, there are certain conditions that will render supplementary bonding unnecessary, those conditions can be found in your OSG and your bible.
This is notifiable work, are you registered with a scam? From what I have got from your previous posts you are working alone right?
Not unreasonable points. Over to you Lofts/Lofty/Lofty83
cheers
4mm bonding should hold the pipework and washbasin together.......no prob.
please dont do that sintra. Can you not see know that I would really bennefit from being allowed on to the training forums, even though its not decned for people like me. Im doing my best mate and your just threatening me all the time.
no I am not registered, I work for a comapny and somehow that covers me. someone else is testing after ive gone to the next job.
I remember asking you if you needed a hand murdoch think I was willing to work for £40 a day or something but you said sorry mate. then you slate me at every chance becasue I dont know certain things ( you could have said well you can come and work with me I cant pay you but I can pass on my knowledg) but did you no like most other people
Not slating you matey, are you a member of a scheme? Simple question.
If you work for a company, seek guidance from them. You need to be absolutely sure you can carry out this work, you also need to know what you are doing and why. So why is no one supervising you mate?
lofts an Internet forum is not the place to learn to be a spark. As for the trainee forums you have no chance as this is the place to advice the members on the correct procedures. You have been given advice on the open forums about the correct way to do things but just carry on in your own little bubble and turn the power on and ride off into the night. You have admitted what you do is wrong but just carry on regardless. I am here to monitor these boards and if I decide to remove threads or members or both in the interests of the well being of the forums then I will do it.
I dont know why no ones supervising me mate I could probably do with some but Ive done most things before theres just a few things I havent done like this and so I was hoping to find out the answers on here. No one ever seems to want to help me tho all they want to do is take the **** because I dont know. that doesnt bother me but not knowing the answer does ill be honest.
Murdoch mate im not part of a scheme no. I work for a comany that does works for housing associations when someone dies they redo the house as its an opportunity to do so before the next people move in
Do you mean the same board but with a Rcd,not a main switch as shown in the link
Reply to additional protection in the UK Electrical Forum area at ElectriciansForums.net
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
