C
craig1000
Hi,
i have ajob to complete which is to urgrade existing DB in a stables & then install small power & lighting. The work is in a external stable block of a equine vets. Off of this existing DB which i am to upgrade shall also be another barn/store outbuilding & another work shop outbuilding.
Now as the elctricity supply comes into the stable block & at this point is where i shall be changing the Db to a 17th dual rcd db so all circuits off of this are rcd protected. The question is where the swa i am running into the barn/stores seperate db does this db also need to be a rcd db/protected, as technically it plus its circuits are already rcd protected by the rcd on the board in the stable block,correct? or not? or should i as good practice install a rcd board in there anyway. At eh moment it has a non rcd db in there, doed it need upgrading?
Sorry if i confuse with my wording & please accept my apoligies if you feel i should know this but i dont & its better to ask than do/assume & have things wrong!
Thankyou in advance!
Craig!
Craig!
