This thread titled "Advertising a system as 4kWp?" is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
don't get me wrong, it will happen sometimes, but usually only for relatively brief periods as the panels will warm up in 1000W/m2 of sunlight unless there's a howling gale, or the air temperature is seriously cold.
not if they wanted to comply with G83 regs, where the nominal voltage of 230W applies - as Power-One discovered when they had to change their 16amp limit inverters to also be capped at 3680W AC output.Are we also forgetting that a 16 amp capped inverter could output over 4kw with high local grid voltage and under 3.68 with a low local grid voltage , explain that one in your advertising literature!!!!
Reply to the thread, titled "Advertising a system as 4kWp?" which is posted in the under the Solar PV Forum | Solar Panels Forum on Electricians Forums.
