Guest viewing limit reached
Hi folks,
I have a mini oven /grill. The maker is ~Severin , I think they are maybe a German company... Received the oven, brand new via Ebay....It is a nice looking / quality machine however it has a two pin plug....
Can I use a reguler three pin plastic converter so I can plug in here in the UK, or would this be dangerous for an oven ? It is a 1500 W ....
Welcome to the forum :)
Just an heads up - you posts require approval as a new member but we are a tad short on staff been online today, I'm heading out so if you don't see your posts coming up please don't duplicate them just return later when staffing levels are up and your posts will have been approved.
Re' Darkwood :)
As above - let us know exactly what the rating plate says. A photo would be ideal, although you may not have permission yet as a new user. Daz
Is it something like this? Severin Table Oven 20L | Crosscraft
As the manual says.
Connection to the mains supply
The appliance should only be connected to
an earthed socket installed in accordance
with the regulations. Make sure that the
supply voltage corresponds with the voltage
marked on the rating label of the appliance.
This product complies with all binding CE
labelling directives.
Everything on the plate as follows :
Severin 1500 W -
There is a Triangle shape,
Art.To 2036
CE ( in large format )
Type 2036
17 EX
Sorry my replies are so slow reaching you, they need to be reviewed first as I am a newbie :sad3:
Btw, There is a booklet with it ( in various languages ) The oven is described as a ~Rotisserie Toast Oven.. Yes it does look a bit like the one in the photo.... Not sure how many Litres this one is though...
If the voltage, etc. does prove to be OK I wouldn't recommend using a euro adaptor. They don't give very good contact and at that sort of power could lead to a bit of local overheating of the contacts. Would be better to fit the correct plug. Assuming the voltage/frequency requirements prove to be OK that is. Daz
To the best of my knowledge a product supplied to the UK market for domestic use is legally required to have a BS1363 plug fitted.
If it doesn't then send it back and report the seller to trading standards for appropriate legal action to be taken against then
if it comes with a 3 core flex, then just cut the mickey mouse plug off and fit a bs1363. if it's 2 core flex, then the applince should have a classII symbol.
Unfortunately, it's way too late to do anything about it now.... Purchased the oven absolutely ago..... It's been in storage... Only recently unpacked it to place in my refurbished kitchen ...... I didn't expect it to have a two pin plug, such a disappointment ..
Wales
Advice for Mini Oven
Kez 8,
Kez 8,
