Advice for Mini Oven | Page 4 | on ElectriciansForums
Discuss Advice for Mini Oven in the UK Electrical Forum area at ElectriciansForums.net
Kez 8
Wales
Hi folks,
I have a mini oven /grill. The maker is ~Severin , I think they are maybe a German company... Received the oven, brand new via Ebay....It is a nice looking / quality machine however it has a two pin plug....
Can I use a reguler three pin plastic converter so I can plug in here in the UK, or would this be dangerous for an oven ? It is a 1500 W ....
You could possibly have taken the back off the oven and seen what colour cable went to what terminals.
For a non UK made cable the colour combinations can be extremely varied.
For anyone interested ….
https://www.gadgetspeak.com/gadget/article.rhtm/753/644073/Severin_KM3888_Food_Processor.html
Just did a bit of research on the company….
Briefly here's what somebody had to say about a Severin Food processor …
β€œ . When I received the processor, I was immediately impressed with the quality of the manufacture and the care taken in the design β€œ
The words above echo, Exactly, my own feelings about my mini oven, superb construction, even though its 2 pin thingy is causing me such bloomin' grief…… :confused5:
Thank you for your timely words, Richard, ..Hmmm, well, it appears I am receiving some mixed messages ….. I am not at all sure how the Ebay guy knows exactly what colour cords I will find once I have chopped off the plug, (After all Severin IS ~German, not a UK make..)
I have, again, written back to him, to gain further clarity …
There is ~No, Way, on the face of this planet, I am going to remove the back of the unit :nonod:….
I will see what the guy says, and IF, I still have my doubts, I will be settling for one of those Schuko converter plugs…which is the next best thing …
Richard, I have to say I find the response from the Ebay seller to be rather compelling,
Please find below our email exchange as follows :
ME –
β€œ For the record, I sure would like to know how you are so sure that, once I’ve removed the plug , I will find that the coloured cords will be the same as the UK ?
When I have learnt elsewhere that with a non UK made cable ( Severin is a German make ) the colour combinations can be extremely varied ???? β€œ
EBAY GUY’S RESPONSE –
β€œ European law bought into force the Harmonised cable directive, which meant that all new electrical products made after 2006, using electrical cable and flex had to use the same colour codes.
your oven is using HO5VV-F3X0.75 3 core flex, it should definitely be using these colours to identify live neutral and earth.
When you cut the plug off, if you see different colours, I would be very interested to know… β€œ
End of response.
I would be ~Most, interested to learn what your estimation is regarding his words ? ?? :whatchutalkingabout
I think you need to make a decision about what you are going to do rather than continue to agonise about it.
The chap from Ebay is correct that the cable colours in Europe have been harmonised to be the same across all countries in Europe.
Live (or line) is brown, Neutral is blue, earth is green and yellow.
Your cable is made by a Chinese manufacturer who may not be aware of this.
However that manufacturer is a major specialist in flexible cables, distributing across the world and so should get things right.
Just choose an option and go for it.
If it does not work then you can choose another option later.
Oh you don't know the half of it mate ! :32: ... Had to bin all my food ....
I've been reduced to munching on the grass... along with the cows and sheep ... :sad_smile:
Any excuse to be near the sheep... :)
Not so simplez ! ...... Here's my latest response to the Ebay Guy ....
" Though what you say is correct I am told that as the cable on my oven is made by a Chinese manufacturer , it is possible they might not be aware of European Law.
I am in significant dillema over this because, once I chop the 2 pin off, There is ~No, going Back !
IF, the coloured cords turn out ~Not, to conform to European Specification, but instead are a non typical array of colours, I am done for...
There would then be no safe way of affixing a three pin to foreign colour wires without employing a savvy professional to come and do it, which would cost me a small fortune, just in petrol mileage alone ! ( I live out in the sticks )
Thus the oven would be rendered useless, and might as well be trashed. I just ~ Do Not, want to take that risk ...
So the only alternative, is either your Cable adaptor or a regular Shuko, flip top, plug adaptor.
Could you tell me, please, which of the two, in your estimation, would be the ~ Most, reliable, , ie in avoiding the contacts getting hot, which is my main concern...
I can see from the spec sheet that the cable takes 300 / 500 V, which, even to my novice intellect sounds pretty impressive...
Also, in that the cable is designed, specifically, for converting an extension cord , several pieces of garden equipment being used at the same time, could well, safely, exceed the comparatively small load ,1500 W, of my oven, Yes ? "
Owing to your desire not to make any physical changes then your option is reduced to fitting an adapter onto the supplied plug.
Make sure the adapter fits the socket on your machine.
Make sure it is an earthed adapter.
Make sure it can take at least 10A.
Make sure the adapter can take a standard plug top fuse (most do).
If your ebay seller sells an adapter that fits your plug, is earthed and rated for at least 10A then it should be OK.
You can check on the cable colours without chopping off the plug, just take the cover off and have a peek. .
IF I could have done, I would have done ! I am not, ~Totally, dense .. :sad3: The 2 pin is a rigid molded plug, there is ~No Way of getting into it ....
Hey, btw, I like your " Man Who Fell To Earth " Avatar.... are you too from another planet ? , I sure am... This limited plane of existance is so darn... well, Limiting ! I cannot believe I am here spouting on about a mini oven.... I mean, there are entire Universes to explore out there, a multitude of vast spinning galaxies within which to express our beingness, Eh, Stan ! :shades_smile:
...... Back to "Human " guise.... :seeya:
Will certainly bare this in mind, Richard, though Y'know, that Ebay guy sure is ~Emphatic, about
the European Law...... He absolutely insists as follows :
[h=3]" If China is sending products to Europe then they MUST conform to the wiring colour codes, especially if they are sending it to a German company, who would have VERY strict quality assurance. "[/h]
I think in the end I'm gonna call heads or tails and flip a coin.....
It's the ~ ONLY way out of this Battle of the Electrical Giants .....:sad_smile:
Drivin me round the twist, if I weren't round it already ! ..... :banghead::banghead::banghead:
Reply to Advice for Mini Oven in the UK Electrical Forum area at ElectriciansForums.net
  • [DIAL] What Is The Cancellation Policy For Expedia?
    π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ π•‘π• π•π•šπ•”π•ͺ. π•‹π•™π•šπ•€ π•žπ•–π•’π•Ÿπ•€ π•ͺ𝕠𝕦 π•”π•’π•Ÿ π•”π•’π•Ÿπ•”π•–π• π•žπ• π•€π•₯...
  • Song words.
    All I Wanna Do Is Make Love To You View: https://www.youtube.com/watch?v=OAfxs0IDeMs
  • What is the refundable option on 𝔼xpedia? Cancellation Policy
    What is the cancellation policy for 𝔼xpedia? π”Όπ•©π•‘π•–π••π•šπ•’ 𝕠𝕗𝕗𝕖𝕣𝕀 𝕒 π•˜π•–π•Ÿπ•–π•£π•’π• 𝟀𝟦-𝕙𝕠𝕦𝕣 π•”π•’π•Ÿπ•”π•–π•π•π•’π•₯π•šπ• π•Ÿ...
