A
AdamW
Hello all,
Im new to the forum and after some advice.
I am replacing a single light fitting (ceiling rose) with 4 downlights. The downlights are supplied with Scolmore Click Flow connectors. On each connector are 4 terminals (live, neutral, earth & loop). The L, N & E connect to the female flow connector attached to the downlight itself. The loop does not connect to the downlight connector.
My question is - How do I wire in the 4 new downlights?
I have made a picture of current wiring setup (LHS of image) and what I think the new wiring should look like (RHS of image).
I have numbered/lettered the terminals to make easier for anyone wishing to offer advice.
Any advice you are able to provide will be greatly received.
Adam
- How do I wire the switch in?
- And what is the loop terminal for?
Adam
