Advice on buying generator please
Hi
I am looking at purchasing and running a drinks cooling machine to run on no mains electric what so ever!
The company that sells the machine have advised the following
Frequency: 50Hz Rated current: 5.5A Rated input: 800W
This machine is a liquid to liquid based (water and anti freeze bath) heat exchange and only runs when liquid is passing though it. And will only operate when I open the tap and fill a glass up from it so it will not be running most of the time
The two option I am considering is buying a generator inverter and battery and charging the battery up as required. Or just running the generator when it is in operation. So what do you think?
My #34 second paragraph- you have not provided the information.
Im not quite so sure what you are asking hear but......
As I said I am no expert in batteries and brands of but I reckon there will be a difference between the battery life and guarantees/specifications of performance when it is used primarily for a few seconds to crank an engine and when used regularly for prolonged discharge to a deeper depth of discharge. Hence the rather odd phrase 'leisure battery'. I know nothing about the Platinum make.
To do the analysis of battery and generator charging I need to know how long the battery alone must provide power and remain above 50% discharge. In my clients case from shut up shop 7pm Saturday evening to opening up 7am Monday morning.
Leisure battery or better term deep cycle batteries are not what you find on a car! car batteries use a different type. Commonly refered to as CCA (cold cranking amps). A deep cycle battery will simplely not start an engine and a CCA battery will not last as long as deep cycle.
Anyone in the motor trade will know all about Platinum batteries. They are one of the best!
But again I am not quite so sure what you are asking hear. Because if I had the 200AH battery in question that I would discharge it to 50%. Then what size generator would you recomend if I wanted to charge it up for say 30 minuts?
ice man,
ice man,
