Advice on faults and Ideas for fixes | Page 5 | on ElectriciansForums
  • If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
You're viewing the old forum category for electricians jobs. That's fine and you can reply to threads and contact the person who posted the jobs etc too. But for new electricians jobs post to the new job forums instead; Electricians Available for Work Post Here, People seeking domestic electricians post here, People seeking Commercial or Industrial Electricians post here
Discuss Advice on faults and Ideas for fixes in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
His point was that anybody claiming to be part p approved/registered is a liar.
I am on a government register of approved part p electricians.
I didn't know that the government kept such a register, where can this be found?
Here
Home - http://www.electricalcompetentperson.co.uk/
The Registered Competent Person Electrical single mark and register went live on 30th June 2014 and was officially launched in Parliament on 2nd July 2014. It was created following an agreement between all Government-approved electrical Competent Person Scheme Operators in England and Wales.
The single mark and register aims to raise awareness of electrical safety in the home by simplifying the task of finding and checking a competent, registered electrician.
All electrical enterprises listed and permitted to display the mark are registered to undertake work on domestic electrical installations under the Competent Person Scheme, introduced by the Government, to allow individuals and enterprises to self-certify that their work complies with the Building Regulations.
These electricians meet strict qualification requirements and their work is regularly assessed by their electrical Competent Person Scheme Operator to ensure their ongoing competence. The list of Government-approved electrical Competent Person Scheme Operators, their requirements and how they are authorised can be found on the Gov.uk website.
This mark and register is open to all competent, registered electrical installers in England and Wales undertaking work for householders.
Thought i'd check back in with an update.
So the sparky has come back and has advised that they can heighten the plug that is low to the skirting board. Would mean pulling a board, fitting an electrical fitting/box and extending the cable from there.
In regards to the lighting, they've discussed looking at the original kitchen light wiring to see if they can spot the issue. However as the issue only happened after the works my moneys on the new switches potentially bringing an old issue to the surface. So it seems a little fruitless.
In regards to the issue of my downstairs sockets tripping due to the use of my blender, there telling me that it's likely something i should learn to live with due to having older wiring. I mentioned about completing the downstairs socket so it could be upgraded from a 16amp circuit to a 32 amp circuit but was told that it could be a lot of work and not to worry about it and maybe consider it in the future if i knocked the lounge through.
And in regards to the outdoor PIR security lighting, rather than troubleshoot the current wiring, probably best to spur off a feed from an upstairs plug socket and run the security lighting from that.
After the last visit to explain all the above to me, they also replaced my downstairs WC light (which is also connected to the extractor fan just for info) And now i find that every 1 in 10 times i turn this light on it flips my downstairs lighting circuit.
Any advice? :)
Hi - it needs testing, but sometimes this can be caused by a failing light switch’s contact bounce. Or not :) .
Thanks for all the replies guys it's been super helpful to hear everyones tips and opinions. I think a lot of you were in agreeance that i let the sparky advise on the fixes and give them an opportunity to rectify the situation. It dosn't seem to me that there particularly interested in troubleshooting the issues. Do you think it's time to part ways and get someone in with more experience to finish the job? And if so is anyone near my neck of the woods (Surrey) that could help?
@Wilko - Thanks for the reply. Would this likely still be the case when using an RF light switch as opposed to a traditional mechanical switch though?
Hi - you are right, RF light switch failure modes likely to be different. If this is an RF light switch that causes a trip then the receiver unit would be on the list of suspects, along with a wiring fault.
@Wilko - Yeah, That's what i thought. What's weird is that the other new switches on the same circuit have never tripped the downstairs breaker but turning on the new WC light with the new switch does. The bulb has gone from 8.5w to 24w LED (dome light) for what it's worth. I have the same setup in the upstairs bathroom and it's been solid. It feels like the new switch and light have either tapped into an existing wiring issue or tat they've been badly installed recently.
Reply to Advice on faults and Ideas for fixes in the Electricians Jobs area at ElectriciansForums.net
Thanks guys, I'm going for the safe option and take your advice in getting a qualified electrician to look at it. We've inherited these issues so...
It does seem to me that there's a capacitively coupled voltage to each set of downlights (on the light side of the switch), and when you put the...
Electricians Jobs, Electricians Mate Jobs and Electrician Apprenticeships
Thanks for visiting ElectriciansForums.net, the worlds largest electrical and electricians community. This area of the website is for those who are looking for electricians jobs, electricians mate jobs, or electrical apprenticeship schemes. We have opened up our website to the world after being UK-only for more than 10 years. We now have jobs posted to the forum for domestic, industrial and commercial electrical work from all over the world. Anybody is welcome to register to our forum for free. You can post jobs you have going, or know of. And you can also post to the forum if you're looking for employment or recruitment. Full or part time. Just let us know the full details of the job you have on offer or are looking for and we'll do the rest.
Also note that we have tiling jobs, and plumbing work too.
