Advice on if quote / estimate is pricey | Page 2 | on ElectriciansForums
Discuss Advice on if quote / estimate is pricey in the UK Electrical Forum area at ElectriciansForums.net
Djhonson
England
Hi all,
I am a new home owner and have had a quote on some electrical work I wanted done in my home. I was wondering on if someone could give some advice on if the estimate I have been given is over priced:
Estimate for the following electrical work -
• Full electrical installation condition report.
Entrance Hall -
• Supply 2 gang light switch.
• Supply 1x single socket.
Lounge -
• Remove 2 way switch.
• Change 2x single sockets to doubles (1x usb)
• Supply 2x double socket faceplates.
• Add double socket and relocate tv point to chimney breast.
• 6x new downlights.
Kitchen-
• 4x double sockets (1x with usb).
• 1x 2 gang light switch.
• 1x 1 gang light switch.
• 4 x new downlights.
Dining room -
• 4x new downlights.
Utility -
• Change trunking and tidy up.
• Replace light fitting for round LED.
• Add double socket.
Office -
Landing -
• Sink in 1 gang switch.
Master Bedroom -
• Sink in all sockets and switches.
• Add additional double socket.
• Change single sockets to doubles.
• Move pendant to centre.
Bedroom 2
• Move switch to the other side of the door
Bedroom 3
Outside -
remove outside light and install client supplied light to new location.
Total = £2100.
Something to consider is the amount of light in a workroom (Kitchen) are the four downlighter's quoted for additional or the total number, it may need additional light to be effective either under unit lights or additional downlight's, I used to work on 1:1.5M of ceiling area, but that also depends on the ceiling height above the worktop and how many wall cupboards, but is a good working figure for LED lights, also unless a bungalow these need to be fire rated if a habitable room is above.
I was charging £50 per point on rewires 15 years ago when I did farely regular rewires and 100mtr drum of 2.5 cable was about 40 quid.
I rarely do per point pricing these days but I did I would charge more like £90-95 per socket , there is simply no money at 50£ per point if that includes labour and materials at todays cable prices
I agree - £50/point is years out of date in my opinion.
Hi all,
Entrance Hall -
Lounge -
Kitchen-
Dining room -
Utility -
Office -
Landing -
Master Bedroom -
Bedroom 2
Bedroom 3
Outside -
Total = £2100.
Not expensive.
A lot of self employed sparks charge up to £75-100 per point.
This is lots of points and plenty of work as well as lots of fannying about.
£2100 is a fair price imo, maybe even on the cheap side. Rewiring would be easier.
Not expensive.
How have you come to the conclusion that rewiring would be easier.
Reply to Advice on if quote / estimate is pricey in the UK Electrical Forum area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
Depending on the location of the 2 CU's and the quality of materials I'd say £10K-12K. If they're potential tyre kickers don't waste loads of time...
    • Informative
