Advice on old style junction box for cooker - need to replace cooker, told box illegal? | Page 3 | on ElectriciansForums
Discuss Advice on old style junction box for cooker - need to replace cooker, told box illegal? in the UK Electrical Forum area at ElectriciansForums.net
Katoli
North Wales
Hi everyone, there is an electrical cooker already in situ and still connected to this junction box. Have been told box is illegal. I have no idea why, box has been checked inside and is earthed. Can anyone tell me what the issue is please so that I know how to install the new cooker? Big thanks in advance.
[ElectriciansForums.net] Advice on old style junction box for cooker - need to replace cooker, told box illegal?
I know...and it's not good.......but it's not plastered in the wall. How long ago was it done, was it a good connection and how long has it lasted? 25 years ago, I'd have used through crimps....so what?
What's wrong with ply....compared with timber and plasterboard?
Thing is, nobody knows do they. If I got some 'arching or sparking', where could it be happening, that's the issue with all these joints when there's a problem, like countless threads we've had here.[/QUOTE]
I know what you're saying but that's how things were done then. If it was done DIY there would be more chance of problems than if it was by someone who knew their job.
You've come across it. Would you say it's a bad connection? No access, I know, but there was no regulation insisting upon it.
Current requirements take into account (much more) for the interference of the lesser qualified or, to some extent, the non qualified. Hence, I feel, the market for upgraded methods of connection has risen.
A generation before that you could have found porcelain 'screwits' on vir, which I personally hate....but methods evolve.
This is the current connection (no pun intended lol) which has been in place since before I bought this property 26 years ago. I had a new cooker delivered from a major high street retailer and they said they could not install it because the setting was "illegal". Is it worth my ordering a cooker with install from a different major retailer and see if they'll just install the cooker, or am I just going to come up against the same "illegal" issue?
Hi OP. As you have already been told, the only issue is with the dangling cable. Get some white plastic mini trunking and fix it to the wall for the cable going to the new cooker, when you get it. Best to fix it properly rather than use adhesive alone as the heat will affect the adhesive.
If the new cooker people say it's 'illegal' again just ask "What part of BS 7671 does it not comply with?" Ask to see the actual print in the Big Yellow Book. That should stop the muppets in their tracks... If they try and BS you tell them that you will question their comments on an electrical forum, and you will state company name and installer name... See what they say then.
Why? A very high percentage of joints in houses were, at one time, inaccessible.....and not against regulations.
Something concealed in a JB in a ceiling void is inaccessible, but common practise for some years, I concede that. A joint in a wall, done in connectors, covered in ply, plastered & tiled over, is a whole different concept IMO
I know me & ipf, have taken it a bit off topic, but that's the sixth same suggestion on cable restraint & mini trunking. Just saying :)
Very true mate but the OP stated the same thing on his second post so I thought I would give my full opinion.
We are really trying to brain-wash him into knowing its not "illegal" really... :tearsofjoy:
I would disagree with that.
Perhaps you could inform us which edition of the Regulations allowed connections to be inaccessible?
Just found an old 14th...B.73....joints for non flex cables shall be accessible for inspection, not applying to cables buried underground or enclosed in building materials....so certainly not in all situations.
Those joints had to be: soldered, brazed, welded, mechanical clamps, or of the compression type.
Mechanical clamps could not be used within the fabric of the building.
Further mechanical clamps and compression-type sockets shall securely retain all the wires of the conductors.
.....as per reg....fair enough. :cool:
Like I said earlier on, though...25 years back, I'd have crimped them.
Not 100% sure what a mechanical clamp is?
Initial thoughts were a crimp, but wouldn’t that be a compression type?
Also wondering why all conductors have to be clamped or compressed?
Seems to rule out repairing or extending just one conductor.
Yes, you would have done. But many of those dreadful hidden junctions were done by kitchen fitters who had no knowledge of any wiring regulations. It really is a pity that electrics in kitchens has been removed from the special location list. As it was a kitchen electrics tragedy that was one of the drivers behind the emergence of Part P.
MP's daughter electrocuted - https://www.standard.co.uk/news/mps-daughter-electrocuted-6939286.html
Yes. Nothing comes to mind regarding mechanical...unless it's a screwed connector block.......God forbid!!!
I think when they say all, they mean all affected, such as a damaged core or a required joint.
Reply to Advice on old style junction box for cooker - need to replace cooker, told box illegal? in the UK Electrical Forum area at ElectriciansForums.net
Use wago connectors instead, much easier and safer I think
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
