spadge47
Hi all,
A couple of guys at work are getting return visits to properties because they have been taking the earthing conductor into the new AMD3 metal boards through a separate hole than the tails. Apparently it is against these regs. Now I have read it and I am seeing it from both sides but I need your help.
We have been using the wylex boards with the wylex tail glands, and they have the 2 holes in it ( for line and neutral), however when explaining that if you have to take the earth through the same hole then surely these glands would have 3 holes ? The reply was to 'drill a 3rd hole then'. :thinking:
So please could I have some clarification on this. Do you have to bring the earthing conductor through the same hole as the line and neutral tails for metal boards??
Please could you give me your answers and reasoning please
