Bobbynoggles
We are changing a bathroom cabinet and the old one had a cable on it which is coming out of the wall, I'm assuming it is for a light fitting in the cabinet (which it didn't have). Our new cabinet doesn't require any power so I'd like to get rid of the wire. The new cabinet will need to go on the wall slightly higher than the old one, as I'm well over 6 ft tall, however the cable will be in the way and so i won't be able to fit the cabinet as it won't sit flush to the wall. Is there anything i can do along the lines of snipping the cable, taping it off and pushing it in the wall so it sits flush to the surface. There doesn't seem to be any wiggle in it, in that i can't pull it or push it in.
Thanks.
Thanks.
