Kenny29376
Hi I have an AEG ceramic hob and it is 6.4kw nominal power can I use H05v2v2 ff heat resistant cable.
Discuss AEG ceramic hob wiring. in the UK Electrical Forum area at ElectriciansForums.net
get the appliance first. you may need to use ring crimps.So loads of advice. I'm going to order 2m of 4mm2 flex from cef and some bootlace ends and fit this then I know it's right.
Hi so am I best using ring crimps like the yellow ones or non insulated ones. The hob has 4 screws in so could take them out and use these if that's safe and allowed.get the appliance first. you may need to use ring crimps.
all depends on the terminals in the appliance. some use ring crimps, some just have the wires inserte alongside the screw ( with ferrukles if flex). have you got a photo of the terminals?Hi so am I best using ring crimps like the yellow ones or non insulated ones. The hob has 4 screws in so could take them out and use these if that's safe and allowed.
It does say that but we are self isolating due to corona virus and being high risk. So i have to do it myself. I'm an engineer so can manage connecting a cable that's why I want to know correct way to do it with the correct cable.The instructions probably say it must be installed by a competent electrician!
What I was alluding too was that Apprentice's need not apply, if everything had to be fitted by qualified electricians, apprentice's could not exist, to be honest any type of engineer is capable of wiring a hob and reading a few diagram's on the back/underside of an appliance, it was not aimed at you, but the stupid manual no offence was meant.
I'd like to think that the engineer was the one who created the diagrams......to be honest any type ofengineertechnician is capable of wiring a hob and reading a few diagram's...
Reply to AEG ceramic hob wiring. in the UK Electrical Forum area at ElectriciansForums.net
