It is not a novel to read while in bed.It’s a big book of regulations.
If I everything was “you must do this”, “you must do that”, “ you must not do the other” then it would be even more boring than it is now reading it cover to cover
“Shall” and “must” mean the same thing… you could interchange those two words in any of the regs and it would mean the same.
If its grammatically incorrect, then it wouldnt be in the regs at all.They aren't as interchangeable as you would think, swapping shall for must in the regulations would make them grammatically incorrect and potentially change their meaning.
What i meant was that as long as the sentence still made sense, then shall and must can be swapped.
I wouldn't say one is as "serious" as the other... even the ten commandments used "Shall" (which could be down to translation, of course)
I think ill just sit and watch some more python videos
Try a search for the CFGAR1-BDJust did a bit of digging as I know there have been changes to these boards over the years, but can not find anything which confirms if aluminium was ever used for the enclosure. I know they used to be (probably still are) cast, rather than pressed, which might account for the odd feel it had when drilling.
Not listed on the Bg site as far as I can see, but lots of other Sites, all saying aluminium.Try a search for the CFGAR1-BD
It may not put an end to the debate as it's now an obsolete part number.Not listed on the Bg site as far as I can see, but lots of other Sites, all saying aluminium.
If this is indeed the case, it should put an end to the debate of whether steel is effectively the only permissible material.
I wonder exactly when it became obsolete - prior to, or after, introduction of requirement for non- combustible material?![]()
Still available though and 18th compliant.
Nuisance tripping? Where? How?I don't see an argument in favour of such distribution. It's likely that some sparks will take that sort of approach, but I'd expect most would follow a combination of logic, regulatory guidance and sound engineering judgment to limit the possibility of overloading and nuisance tripping.
Given the potential leakage from dish washers, washing machines and fridge freezers, not to mention a plethora of other appliances likely to make their way into modern homes, I'd question the ability of anyone designing such an installation.
It's not a case of 'we've always done it this way' - quite the opposite, in fact, and I don't consider the questions you're applying to such design to be sufficient to ensure a problem free installation for the modern home.Nuisance tripping? Where? How?
Q1? Is it safe? Yes.
Q2? Is it legal? Yes.
Q3? Does it protect against arcing? Yes.
You may not see an argument for it, and more will be on your side because of: we have alwasy done it this way. My point is that as AFDDs are expensive and mandatory with copper cable prices rising as world copper prices rise, these sorts of installations may be coming soon, and be quite common.
As a side issue, the British are famous for over-sizing cable. 6mm to a hob when 4mm will do it. 1.5mm for lighting when 1.00mm can do it, 2.5 from an FCU to an appliance when 1.5mm can do it, etc.
Tell me where that installation would give problems? All heavy appliance are on their own radial. As are the cooking appliances - a 3kW oven or hob with 13A plugs are not on the ring. The ring will take few heavy current appliances and these used only for very short periods. The installation will be sound indeed with high protection.ensure a problem free installation for the modern home.
