AFDD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! | Page 4 | on ElectriciansForums
Discuss AFDD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
Well, tell JPEL 64 that then because they require it, and they are allowing a MUCH greater energy with an SFDD to melt the cables and start a fire, so it is somewhy hypocritical & contradictory of them.
Mind that’s not new, but it is also not of my doing.
The manufacturers don't specify how AFDDs detect arcs but you can get a good idea from patents in the public domain. (one attached). The trip algorithms are quite specific in an attempt to separate dangerous arcing from (say) a spot of welding or a sluggish fridge thermostat. This is a problem, wiring has evolved to the needs of each territory - in the US the key concern has always been stopping fires from their high-current radials in wooden buildings. In the UK the priority is protection against shock from the higher voltage, with arc-related fires less common in RFCs in brick buildings. If AFDDs are optimised for the US then they aren't optimised for the UK.
I'm not aware of any research projecting the 'benefit' of AFDDs in the UK and it's possible the benefits are negative. If we are obliged to give up the inherent fault tolerance of RFCs to make AFDDs work then their adoption may increase the incidence of fires, especially considering the higher flammability of UK PVC insulation compared to US (UL certified) wiring.
It could go either way but until some proper research is published showing that UK fire risk would be reduced by the introduction of AFDDs I wouldn't go near one.
  • US20130226479A1.pdf
I can't take the credit for this @essex as it was a mate at work that pointed it out to me. I was initially a sheep, like most, who believed that the AFDD's should be detecting most arks.
As @netblindpaul has pointed out "If, the maximum fault energy to cause a fire is required to be limited by an RCD to 0.3^2 x t, then why is it allowed to be 2.5^2 x t for an AFDD?"
I presume it's down to cost. When you look at how the AFDD's detect arks then if they were to detect 30mA then there is going to be lots of nuisance tripping, unless the detection device is more fine tuned. This will increase the cost of these even more.
Matbe it is because RCDs are already in place currently for most high-risk circuits so no need to replicate.
Reply to AFDD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! in the UK Electrical Forum area at ElectriciansForums.net
Crikey, is that the time???!!! I must get some sleep soon as I have a busy day ahead, and looking forward to working alongside a forum member...
View: https://www.youtube.com/watch?v=t1TcDHrkQYg
