Here's roughly what you would need for the 6Volt Valve.....sorry for the delay in posting up, was in my tool boxes looking then when I came back the browser decided to keep bouncing me to Google Adverts..... A Bridge Rectifier, a Voltage Regulator Integrated Circuit (with a heatsink that clips on or goes on with a 4mm Bolt) a reservoir capacitor for the Regulator, a Resistor for the regulator(according to the rating on Data sheet) A 1N53 or 1N54 Rectifier Diode, or similar to protect the LED, Along with a small current limiting resistor...also a 1N5400 or a P600J Rectifier Diode to protect the circuit from return current when the relay coil de-energises, this goes onto the +Ve side of the relay coil...use the Relay switch to turn on/energise the coil of the solenoid N/C Valve on the Air Line by powering on the 6 Volts DC.....the LED is to indicate that the Valve is open.... Use the 12 Volts from the coin operated timer to close the relay and switch on/energise the 6 volt circuit by connecting the Rectified supply after the Bridge Rectifier... Also in the photo are some plastic standoff clips(handy for the Vero Board) and a few spade crimp/Inline crimp connectors which would also be handy... Look up Vero Prototype Circuit board (or circuit stripboard) to see the type of DIY board to use....
- - - Updated - - -
