Hello all
I hope you are well.
I had a new Alarm Panel installed in January and all was working well until I got a new Consumer Unit installed Last Week which has RCBOs.
The previous Unit was just a Fuse Box.
The Alarm Panel is on its own Circuit connected via a Fused Spur.
The RCBO for the Alarm Circuit will not turn on.
if the Wires in the Fused Spur for the Alarm Panel are removed then the RCBO will turn on fine.
As soon as the Alarm Panel is connected again, the RCBO Trips.
The connection from the Consumer Unit to the Spur has been Tested and it is fine.
The Alarm Panel is the following:
Does anyone have any suggestions as to what may be happening?
Thanks in advance
Kevin
Texecom Veritas 8 Com 8 Zone Compact Alarm Panel
Thanks in advance
Kevin
