Leaving the main switch aside, unless something simultaneously affected every single distribution circuit between this board in question and the downstream boards, it surely has to be manual operation.
What sort of cables are feeding the downstream boards, are they mechanically protected?
I have once found several circuits all chafed on poorly installed metal trunking which then got hit causing it to cut into all of them.
I think I'd IR a couple of the distribution circuits, rule out cable damage, and declare that the only logical reason is manual operatiomajority of the of the cables are SWA properly glanded into the top of the board.
