Alternative to bonding water supply?
N
NickD
Just thinking out loud...how about, as an alternative to bonding (MPBC) an incoming metallic water supply pipe, putting a plastic pushfit immediately downstream from the stopcock before any branches and affixing a big warning notice about why it's there?
(Yes, I know pushfits are (allegedly) not the most reliable things in the world, though having said that my mate who was a fitter at the Royal Ordnance Factories back in the mid 1980s told me they were specified as standard fit on all their pipework.)
Ummm...I don't think the installation could constitute an extraneous conductive part...I could see how there could be another extraneous conductive part coming in other than the main and connecting to the installation, but then that second incomer is the extraneous part, not the installation. Not trying to split hairs here but you can't just point at the entire pipework installation and call it an extraneous conducting part.
OK, so say you insert the plastic pushfit immediately downstream of the stopcock, then test the pipework downstream of the pushfit. If the testing rules that it does not test as being extraneous, would you be content not to bond it?
You really haven't got a clue have you? If the installation we are considering is say a house or small office etc built maybe 30 years ago with a solid ground floor and an outbuilding with a mains water supply to it, all installation pipework is metallic and an unvented hot water cylinder has been fitted.
The extent of metal pipe in contact with general mass of earth may well be sufficient to make the installation as a whole an ECP. There is no second incomer, yet there is still an extraneous conductive part there, unless of course you are going to treat every pipe which sticks up out of the floor to feed a radiator as a seperate ECP?
Here's one for you. Cause I have had this myself. The water pipework was not extraneous (>23Kohms to earth). However it had become extraneous via the gas boiler because the gas supply pipework was extraneous. The gas was bonded (10mm (PME)). Would you bond the water separately?
In that case, the water pipes would have such a low resistance to the MET they wouldn't require bonding.
However, >23kOhm don't require bonding, but what lower limit would you say the same?
Seriously, how are you not getting this? If you don't bond the copper pipe in the installation, and it comes live, what do you think will happen if somebody touches it?
But if you're not careful that line of thinking takes us back to the days of yore of earthing metal window frames again. Anyway, enough of this merriment. Excuse me while I go pore over GN8 Chapter 6....
Yes, I realised this. However, I'm still not getting how you think the water in the pipe won't negate the use of the plastic fitting.
He's not the only one not getting it I think!
How exactly is a pipe going to 'come live' if it is not bonded? the whole point of equipotential bonding is to ensure that that the pipework and other extraneous parts does become 'live' if the supply earth connection becomes live through an external fault.
Ah, I see what you're trying to say now. At a splitting hairs level yes I do prefer to think of every pipe coming up as an ECP because the idea of the mass of metal being an ECP sticks in my craw, though I accept the guidance is quite happy to look at it that way.
Re-read what I've written. I'm tired...
I know it did not require it. It was not extraneous in its own right, and only became same potential as the gas pipe when combi boiler was connected. If the boiler was removed it would go back to non extraneous. I still bonded it though as it was new install and I didn't want another spark in future saying "why did he not bond the water" lol and me not being there to explain it.
I think some people need to understand the difference between earthing and bonding.
Bonding is intended to equalise differences in potential between extraneous-conductive parts and exposed-conductive parts.
Earthing is intended to provide a return path for current which may become present in exposed-conductive parts under fault conditions.
Neither bonding or earthing are intended to provide a return path for current which may be come present in conductive parts due to poor workmanship.
I think it's not wise to contemplate too deeply what is truly extraneous or you end up in orange robes with a shaved head sitting on a mountaintop in Tibet going ommmmmmmmmmmmmmmmmmmmm......
There is a very big difference in the rules and the thinking behind those rules, that are applied to ordnance factories and normal buildings, eg domestic houses and flats!!
It doesn't matter if just 100mm of metal gas or water pipe enters a property before being converted to plastic, it will still be bring into that property an extraneous source earth... So officially will need main bonding....
There is a very big difference in the rules and the thinking behind those rules, that are applied to ordnance factories and normal buildings, eg domestic houses.
I mentioned the ordnance factory thing purely in reference to reliability of plastic push fit as a connector system, nothing more.
To be honest, i don't know what you're proposing here?? For electricians to start installing plastic isolation sections to incoming water and gas pipes maybe?? Now that should be interesting!! lol!!
Mostly it was just like a thought experiment to hear other people's input and take on things, which can be a good way to improve my own understanding/grasp of things. It's been useful.
NickD,
NickD,
