Am I liable to pay | Page 3 | on ElectriciansForums
Discuss Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
uk
I rent a property in the UK. All of the sockets in my house were tripping, even when all sockets were switched off. An electrician came out, sent by the estate agent who manages the property. They determined it was an appliance of mine that tripped the power. He said something about why the socket was receiving power when the switch was off, but I'm not sure what it was he said as I am no electrician. Something to do with a neutral wire. I have received an invoice, from the estate agents, for me to pay the electrician as the fault was my appliance. I agree this would be my invoice to pay, however, I could have diagnosed the appliance as the fault myself had the landlords socket not been supplying power when switched off? Please could somebody advise me as to where I stand. Of course I am happy to pay if it is my responsibility. Thanks, Jean.
Hi - it could be a fault in the outlet you normally have the toaster plugged into, or the toaster. Sorry if I missed it, but does the toaster work fine now when it’s plugged into the original outlet?
where in the uk are you? there may be a member near you who could pat test the toaster for the cost of a beer if you took it to them.
you can then go back to the agent with something that disproves the original diagnosis of the electrician.
I'm in cheshire, I'm going to have a look and see who is about and could test it for me, thanks.
To have a faulty toaster causing nuisance tripping when plugged into a socket which is switched off would be very unlucky and not something I can recall having come across[the socket may be Single Pole, but it may very well be Double Pole]. To have the brand new replacement toaster doing the same thing...well knock me over with a feather but I don't think so
Yes that is correct, even when powered on. I don't know if it is relevant be worth mentioning that the trip didn't occur until any socket in the upstairs or downstairs loop, or the boiler attempted to draw power. I.e if all socket were turned off then I tried to turn the socket on for a TV upstairs, the power would trip.
i.,m in cheshire. whereabouts are you. it's a big county.
I recently went to a house with and RCD tripping, it turned out to be the toaster. The occupier had dropped something metallic in the toaster, causing a N to E short. After tipping the metal object out, the toaster worked fine and nothing tripped.
Reply to Am I liable to pay in the UK Electrical Forum area at ElectriciansForums.net
Which rcd is it? Is it one for everything, one for a few circuits?
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
